주요 콘텐츠로 건너뛰기
Lenovo Yoga 710-11ISK Speaker Replacement
필요한 것
  1. Lenovo Yoga 710-11ISK Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Remove the 11 screws located on the back panel using a T5 Torx screwdriver.
  2. Lenovo Yoga 710-11ISK Speaker Replacement: 2 단계, 이미지 1/1
    • Insert an opening tool between the bottom panel and chassis, then pry around the entire perimeter until the five clips detach, releasing the bottom panel.
  3. Lenovo Yoga 710-11ISK Speaker Replacement: 3 단계, 이미지 1/2 Lenovo Yoga 710-11ISK Speaker Replacement: 3 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove the four screws securing the battery.
    • Grip the battery cable connector on both sides of the plug and gently pull it directly from its port.
    • Lift the battery up and out.
  4. Lenovo Yoga 710-11ISK Speaker Replacement: 4 단계, 이미지 1/1
    • Unplug the wire harness on the left side of the computer to disconnect the speakers from the motherboard
    • Remove the white and blue wires from the plastic brackets holding them in place.
  5. Lenovo Yoga 710-11ISK Speaker Replacement: 5 단계, 이미지 1/3 Lenovo Yoga 710-11ISK Speaker Replacement: 5 단계, 이미지 2/3 Lenovo Yoga 710-11ISK Speaker Replacement: 5 단계, 이미지 3/3
    • Carefully remove both speakers and rubber grommets from their mounts.
    • Slide the right speaker underneath the white ribbon wire.
    • Lift the speakers up and out.
결론
Jarrett Stoll
회원 가입일: 02/10/22
385 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 79
