소개
Use this guide to remove or replace the battery on your Lenovo Yoga 710 laptop.
Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 5개
Thank you for posting this battery replacement guide! I’m not huge on computer tech stuff and because of the holidays a lot of repair shops were closed. So, I found this, the tools I needed and bought a battery off ebay and I did it myself. I saved so much time and money(i’m sure) because of these simple instructions. Although I have the 710-15IKB, everything was basically identical. Thank you !
envykiss99 - 답글
Thank you making this guide for a battery replacement!
envykiss99 - 답글
I replaced the battery, but now the computer won’t turn on! what am I doing wrong?
chrismark1 - 답글
I you haven’t yet, try plugging the laptop into power to see if it runs off of AC power.
Worked great. thx
John Smith - 답글
