주요 콘텐츠로 건너뛰기
Lenovo Yoga 710-14IKB Battery Replacement
필요한 것
  1. Lenovo Yoga 710-14IKB Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Battery Replacement: 2 단계, 이미지 1/3 Lenovo Yoga 710-14IKB Battery Replacement: 2 단계, 이미지 2/3 Lenovo Yoga 710-14IKB Battery Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Battery Replacement, Battery: 3 단계, 이미지 1/2 Lenovo Yoga 710-14IKB Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Battery Replacement: 4 단계, 이미지 1/2 Lenovo Yoga 710-14IKB Battery Replacement: 4 단계, 이미지 2/2
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
  5. Lenovo Yoga 710-14IKB Battery Replacement: 5 단계, 이미지 1/1
    • Remove the battery.
결론
다른 20명이 해당 안내서를 완성하였습니다.
Grant Doerksen
회원 가입일: 04/17/17
1,005 평판
안내서 5개 작성하였습니다
Cal Poly, Team S14-G5, Banghart Spring 2017 Cal Poly, Team S14-G5, Banghart Spring 2017 회원
CPSU-BANGHART-S17S14G5
4 회원들
안내서 27개 작성하였습니다
댓글 7개
Thank you for posting this battery replacement guide! I’m not huge on computer tech stuff and because of the holidays a lot of repair shops were closed. So, I found this, the tools I needed and bought a battery off ebay and I did it myself. I saved so much time and money(i’m sure) because of these simple instructions. Although I have the 710-15IKB, everything was basically identical. Thank you !
envykiss99 - 답글
Thank you making this guide for a battery replacement!
envykiss99 - 답글
I replaced the battery, but now the computer won’t turn on! what am I doing wrong?
chrismark1 - 답글
I you haven’t yet, try plugging the laptop into power to see if it runs off of AC power.
Arthur Shi -
Worked great. thx
John Smith - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 37
30일 전: 188
전체 시간: 19,668
