주요 콘텐츠로 건너뛰기
Lenovo Yoga 710-14IKB Battery Replacement
필요한 것
  1. Lenovo Yoga 710-14IKB Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Battery Replacement: 2 단계, 이미지 1/3 Lenovo Yoga 710-14IKB Battery Replacement: 2 단계, 이미지 2/3 Lenovo Yoga 710-14IKB Battery Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Battery Replacement, Battery: 3 단계, 이미지 1/2 Lenovo Yoga 710-14IKB Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Battery Replacement: 4 단계, 이미지 1/2 Lenovo Yoga 710-14IKB Battery Replacement: 4 단계, 이미지 2/2
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
    The connector slides out of the metal housing, not up from the board.
    Matthew Karmel - 답글
    Thanks for the comment! I’ve corrected the step.
    Arthur Shi -
  5. Lenovo Yoga 710-14IKB Battery Replacement: 5 단계, 이미지 1/1
    • Remove the battery.
    i just bought a battery for my lenovo yoga 710-14ikb from ifixit..and now battery is not detected.
    jeffrey orr - 답글
결론
다른 20명이 해당 안내서를 완성하였습니다.
Grant Doerksen
회원 가입일: 04/17/17
1,005 평판
안내서 5개 작성하였습니다
Cal Poly, Team S14-G5, Banghart Spring 2017 Cal Poly, Team S14-G5, Banghart Spring 2017 회원
CPSU-BANGHART-S17S14G5
4 회원들
안내서 21개 작성하였습니다
댓글 7개
Thank you for posting this battery replacement guide! I’m not huge on computer tech stuff and because of the holidays a lot of repair shops were closed. So, I found this, the tools I needed and bought a battery off ebay and I did it myself. I saved so much time and money(i’m sure) because of these simple instructions. Although I have the 710-15IKB, everything was basically identical. Thank you !
envykiss99 - 답글
Thank you making this guide for a battery replacement!
envykiss99 - 답글
I replaced the battery, but now the computer won’t turn on! what am I doing wrong?
chrismark1 - 답글
I you haven’t yet, try plugging the laptop into power to see if it runs off of AC power.
Arthur Shi -
Worked great. thx
John Smith - 답글
Holaa, moltes gracies, m'ha anat de primera.
Salutacions
Miquel Prunera - 답글
Thank you for this easy to follow guide to giving new life to my Yoga. The new (ifixit supplied) battery is now installed and seems to perform well.
The step I found trickiest was to remove the battery connector but I did manage.
I really recommend the ifixit tool kit as well. It is has an aura of quality and is a joy to use
ABC80 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 26
30일 전: 131
전체 시간: 19,347
