소개
This guide will teach you how to remove and replace the cooling fan on your Lenovo Yoga laptop.
필요한 것
Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 4개
Thanks for a great guide! This is a great laptop with a really noisy cheep fan... It makes a high pitch sound even under the low load. Is it possible to make it run any better??
k.kubaitis - 답글
I have searched online for a replacement fan for the Yoga 710-14ikb but havent found any. Is it possible to use a fan for another model, perhaps the 14isk or 15ikb?
I did find this but dont want to wait that long. https://www.aliexpress.com/item/New-lapt...
does anyone know the best place to buy a new one of these fans?
