주요 콘텐츠로 건너뛰기
Lenovo Yoga 710-14IKB Motherboard Replacement
필요한 것
  1. Lenovo Yoga 710-14IKB Motherboard Replacement, Back Cover: 1 단계, 이미지 1/1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Motherboard Replacement: 2 단계, 이미지 1/3 Lenovo Yoga 710-14IKB Motherboard Replacement: 2 단계, 이미지 2/3 Lenovo Yoga 710-14IKB Motherboard Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Motherboard Replacement, Battery: 3 단계, 이미지 1/2 Lenovo Yoga 710-14IKB Motherboard Replacement, Battery: 3 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Motherboard Replacement: 4 단계, 이미지 1/2 Lenovo Yoga 710-14IKB Motherboard Replacement: 4 단계, 이미지 2/2
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
  5. Lenovo Yoga 710-14IKB Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the battery.
  6. Lenovo Yoga 710-14IKB Motherboard Replacement, SSD: 6 단계, 이미지 1/2 Lenovo Yoga 710-14IKB Motherboard Replacement, SSD: 6 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the 3mm screw on the SSD.
  7. Lenovo Yoga 710-14IKB Motherboard Replacement: 7 단계, 이미지 1/2 Lenovo Yoga 710-14IKB Motherboard Replacement: 7 단계, 이미지 2/2
    • Use your fingers to lift up the SSD and pull away from the socket removing it from the laptop.
  8. Lenovo Yoga 710-14IKB Motherboard Replacement, Motherboard: 8 단계, 이미지 1/1
    • Use a PH00 screwdriver to remove the nine 3mm screws.
  9. Lenovo Yoga 710-14IKB Motherboard Replacement: 9 단계, 이미지 1/2 Lenovo Yoga 710-14IKB Motherboard Replacement: 9 단계, 이미지 2/2
    • Disconnect the indicated cables from the motherboard.
    • Be careful when removing cables. Do not pull or yank cables from their slots.
    • Remove the motherboard.
    • If you want to fully remove the motherboard, you must desolder the display cable.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Evan Cruzen
회원 가입일: 11/01/18
253 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G8
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 20
전체 시간: 2,881
