이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
Use blue plastic opening tool to pry the ram cover loose. Carefully lift up the ram cover and remove it from the laptop.
Locate the ram hold downs.
Push outwards on the hold downs to release the RAM.
다른 14명이 해당 안내서를 완성하였습니다.
댓글 4개
Hi, can the RAM be expandable and what is the highest RAM expansion this lenovo YOGA 710-14IKB can take?
Hi Victoria, I replaced the 8GB RAM stick with a single 16GB RAM stick and this does work!
una pregunta, cuantas ranuras de memoria RAM tiene?
One question, how many RAM slots does it have?
It has 1 RAM slot
