주요 콘텐츠로 건너뛰기
Lenovo Yoga 710-14IKB Speaker Replacement
필요한 것
  1. Lenovo Yoga 710-14IKB Speaker Replacement, Back Cover: 1 단계, 이미지 1/1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Speaker Replacement: 2 단계, 이미지 1/3 Lenovo Yoga 710-14IKB Speaker Replacement: 2 단계, 이미지 2/3 Lenovo Yoga 710-14IKB Speaker Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Speaker Replacement, Battery: 3 단계, 이미지 1/2 Lenovo Yoga 710-14IKB Speaker Replacement, Battery: 3 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Speaker Replacement: 4 단계, 이미지 1/2 Lenovo Yoga 710-14IKB Speaker Replacement: 4 단계, 이미지 2/2
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
  5. Lenovo Yoga 710-14IKB Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the battery.
  6. Lenovo Yoga 710-14IKB Speaker Replacement, Speaker: 6 단계, 이미지 1/1
    • Locate the speaker's plug and disconnect it.
    • Follow the wires connected to the plug to locate the speakers. The left speaker will have red wires, and the right speaker will have blue wires.
  7. Lenovo Yoga 710-14IKB Speaker Replacement: 7 단계, 이미지 1/2 Lenovo Yoga 710-14IKB Speaker Replacement: 7 단계, 이미지 2/2
    • Untangle the wires from the plastic hinges of the case to properly lift the speakers out.
결론
Bailey Murphy
회원 가입일: 11/01/18
85 평판
안내서 1개 작성함
UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G8
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 736
