소개
This guide will teach you to remove and replace your trackpad.
필요한 것
Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
