소개
Deze handleiding laat zien hoe je de netwerkkaart van je Lenovo Yoga-laptop kunt vervangen.
필요한 것
Gebruik een Torx T4 schroevendraaier om de negen 5 mm lange schroeven die de cover vasthouden los te schroeven.
Gebruik een Torx T4 schroevendraaier om de enkele 8 mm lange schroeven in het midden los te schroeven.
Haal de zwarte tape, die de bovenkant van de netwerkkaart bedekt, los.
Haal de zwarte en witte antennekabels die aan de kaart vastzitten los. Gebruik hiervoor bij voorkeur een pincet.
Om je laptop weer in elkaar te zetten, volg je deze instructies in omgekeerde volgorde.
다른 7명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 한 개
I haven’t done it yet, but I’m no longer worried in the slightest! Your guide is about as dummy friendly as it gets, and I cannot even tell you how helpful your detailed instructions, ALONG WITH EXACT, CLEAR, and zoom-able pics of every step , PLUS warnings of what NOT to do and how to tell if you’ve screwed it up!!! A breath of fresh air compared what I’ve come to expect anymore online. I get ones like this - a super fast video, cam behind the person, too far away to see what they’re doing & how; The only zoomed-in shots are the before & after; No talking just background music ; Then in the description, where you expect their instructions, you get only stupidity… ie, like, “open laptop, remove wifi card.Put new one in the same way”. Wow, no sh**?! Idiots… Sadly, not exaggerated! So I just had to thank you, this is how it’s DONE! People should follow your example, something might get done (and done right) for a change!! Keep up the good work if this is ur thing! If not, it should be! Thanks again!
