주요 콘텐츠로 건너뛰기
Lenovo Yoga 710-14ISK Battery Replacement
필요한 것
  1. Lenovo Yoga 710-14ISK Battery Replacement, Remove the base cover screws: 1 단계, 이미지 1/1
    • Remove the M2 × 7 mm, Torx-head screws.
    • Remove the M2 × 5 mm, Torx-head screws.
  2. Lenovo Yoga 710-14ISK Battery Replacement, Remove the base cover: 2 단계, 이미지 1/2 Lenovo Yoga 710-14ISK Battery Replacement, Remove the base cover: 2 단계, 이미지 2/2
    • Insert a prying tool (opening pick) between the base cover and the cover and slide it in the direction shown by arrows to separate the base cover from the cover.
    • Remove the base cover.
  3. Lenovo Yoga 710-14ISK Battery Replacement, Remove the battery: 3 단계, 이미지 1/1
    • Unplug the battery connector.
    • Remove the M2 × 3 mm, Phillips-head screws.
    • Remove the battery pack.
결론
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
회원 가입일: 04/22/20
40,298 평판
안내서 16개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,199개 작성하였습니다
댓글 한 개
Hi, do i can replace my laptop battery by myself? or i should go to geek squad in best buy.
Jesse Milani - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 19
전체 시간: 639
