주요 콘텐츠로 건너뛰기
Lenovo Yoga 710-15IKB Back Cover Replacement
필요한 것
  1. Lenovo Yoga 710-15IKB Back Cover Replacement, Lenovo Yoga 710-15IKB Back Cover Replacement: 1 단계, 이미지 1/1
    • Remove the ten 3.3 mm screws from the base cover using the T5 Torx screwdriver.
  2. Lenovo Yoga 710-15IKB Back Cover Replacement: 2 단계, 이미지 1/1
    • Slide opening tool between the base and back cover.
  3. Lenovo Yoga 710-15IKB Back Cover Replacement: 3 단계, 이미지 1/1
    • Lift the back cover.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Stephanie Alexander
회원 가입일: 09/28/17
757 평판
안내서 3개 작성하였습니다
University of Maine, Team S1-G5, Diaz Fall 2017 University of Maine, Team S1-G5, Diaz Fall 2017 회원
UMAINE-DIAZ-F17S1G5
4 회원들
안내서 10개 작성하였습니다
댓글 2개
Hello,
i am looking for lenovo yoga 710 15” laptop lcd and top body part, where lcd fixed. please suggest.
Thanks & Regards,
Vilas
salvivilas@gmail.com
sunilkedar - 답글
You can get the screens for these fairly easily online, the only problem is the special command adhesive that goes with it doesn’t exist. I have been struggling to get this screen to stick using the recommended 3m adhesive alternative. The screen just wont stick! It appears to stick for weeks without issue but eventually this fails.
service - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 14
전체 시간: 3,199
