소개
This guide is useful for any work with the interior computer hardware.
필요한 것
Remove the ten 3.3 mm screws from the base cover using the T5 Torx screwdriver.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
Hello,
i am looking for lenovo yoga 710 15” laptop lcd and top body part, where lcd fixed. please suggest.
Thanks & Regards,
Vilas
salvivilas@gmail.com
sunilkedar - 답글
You can get the screens for these fairly easily online, the only problem is the special command adhesive that goes with it doesn’t exist. I have been struggling to get this screen to stick using the recommended 3m adhesive alternative. The screen just wont stick! It appears to stick for weeks without issue but eventually this fails.
That’s not a back cover. It’s a bottom cover.
Anton Luu - 답글
