주요 콘텐츠로 건너뛰기
Lenovo Yoga 710-15IKB Battery Replacement
필요한 것
  1. Lenovo Yoga 710-15IKB Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Battery Replacement: 2 단계, 이미지 1/1
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Battery Replacement: 3 단계, 이미지 1/1
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Battery Replacement: 4 단계, 이미지 1/1
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Battery Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Battery Replacement: 6 단계, 이미지 1/1
    • Gently lift and remove the battery.
결론
다른 16명이 해당 안내서를 완성하였습니다.
Stephanie Alexander
회원 가입일: 09/28/17
757 평판
안내서 3개 작성하였습니다
University of Maine, Team S1-G5, Diaz Fall 2017 University of Maine, Team S1-G5, Diaz Fall 2017 회원
UMAINE-DIAZ-F17S1G5
4 회원들
안내서 10개 작성하였습니다
댓글 2개
I had to use a PH000 screwdriver and was only able to remove 1 of the battery screws from the original Lenovo battery. Any suggestions on how to remove the others? Where can I get replacement screws?
karenosickey - 답글
The battery cable requires a lot of force to disconnect; tweezers won't cut it. It's also difficult to reconnect the battery. I used two pairs of needle-nose pliers to squeeze the connector into the socket on both sides.
jkvmyxud - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 80
전체 시간: 18,754
