이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 한 개
I had to use a PH000 screwdriver and was only able to remove 1 of the battery screws from the original Lenovo battery. Any suggestions on how to remove the others? Where can I get replacement screws?
