주요 콘텐츠로 건너뛰기
Lenovo Yoga 710-15IKB Solid State Drive Replacement
필요한 것
  1. Lenovo Yoga 710-15IKB Solid State Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Solid State Drive Replacement: 2 단계, 이미지 1/1
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Solid State Drive Replacement: 3 단계, 이미지 1/1
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Solid State Drive Replacement: 4 단계, 이미지 1/1
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Solid State Drive Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Solid State Drive Replacement: 6 단계, 이미지 1/1
    • Gently lift and remove the battery.
  7. Lenovo Yoga 710-15IKB Solid State Drive Replacement, Solid State Drive: 7 단계, 이미지 1/1
    • Remove the one JIS 1 screw holding the solid state drive in place.
  8. Lenovo Yoga 710-15IKB Solid State Drive Replacement: 8 단계, 이미지 1/1
    • Gently pull the solid state drive out and up to remove it from the connector.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Andrew Keenan
회원 가입일: 11/30/17
173 평판
안내서 1개 작성함
University of Maine, Team S1-G5, Diaz Fall 2017 University of Maine, Team S1-G5, Diaz Fall 2017 회원
UMAINE-DIAZ-F17S1G5
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
No need to remove battery. No need for tweezers.
Shane Whittet - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 36
전체 시간: 7,063
