소개
This guide will show you how to replace the RAM in your Lenovo Yoga 710-15ISK laptop. The memory of your laptop is an essential component that determines how many programs can be running at once. If you find your laptop is running slowly, you may want to upgrade or replace your memory. When buying replacement RAM sticks, check your laptop’s specifications to ensure it’s compatible—RAM comes in a number of shapes and configurations, and getting the wrong kind will cause your RAM to run slower than it should or not at all.
필요한 것
Flip your laptop over so the bottom is facing upwards.
Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver.
