주요 콘텐츠로 건너뛰기
Lenovo Yoga 720 Bottom Cover Replacement
필요한 것
  1. Lenovo Yoga 720 Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 1/3 Lenovo Yoga 720 Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 2/3 Lenovo Yoga 720 Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    T5 Torx Screwdriver
    $5.49
    구매
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Start by flipping the device over so that you see the screws.
    • Remove seven Torx T5 short screws.
    • Remove three Torx T5 long screws.
  2. Lenovo Yoga 720 Bottom Cover Replacement: 2 단계, 이미지 1/3 Lenovo Yoga 720 Bottom Cover Replacement: 2 단계, 이미지 2/3 Lenovo Yoga 720 Bottom Cover Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    구매
    • Starting from the USB port, use your opening tool to gently pry up the case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop in the order shown by the arrows.
    • Do NOT pry along the top side, or you risk damaging the casing. Stay with the arrows.
  3. Lenovo Yoga 720 Bottom Cover Replacement: 3 단계, 이미지 1/3 Lenovo Yoga 720 Bottom Cover Replacement: 3 단계, 이미지 2/3 Lenovo Yoga 720 Bottom Cover Replacement: 3 단계, 이미지 3/3
    • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the case.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Aiden
회원 가입일: 09/19/15
17,429 평판
안내서 21개 작성하였습니다
댓글 한 개
Can’t seem to find information about this but why should I discharge the laptop to 25% before I do this?
I bought a new wifi card that I will put in.
Björn Ridell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 21
전체 시간: 7,339
