소개
This guide will show you how to remove the fingerprint reader.
부품
지정된 부품이 없습니다.
Starting from the USB port, use your opening tool to gently pry up the case.
Pry along the laptop in the order shown by the arrows.
This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
Remove four J1 Philips screws.
Remove one J1 philips screw.
Lift the battery slightly using your plastic opening tool.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
Aiden,
How do I repair the power button on this model? It no longer clicks and I have to use a paper clip on the opposite side. Looks like I need to remove the motherboard to gain access
