주요 콘텐츠로 건너뛰기
Lenovo Yoga 720 Speaker Replacement
필요한 것
  1. Lenovo Yoga 720 Speaker Replacement, Bottom Cover: 1 단계, 이미지 1/3 Lenovo Yoga 720 Speaker Replacement, Bottom Cover: 1 단계, 이미지 2/3 Lenovo Yoga 720 Speaker Replacement, Bottom Cover: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    T5 Torx Screwdriver
    $5.49
    구매
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Start by flipping the device over so that you see the screws.
    • Remove seven Torx T5 short screws.
    • Remove three Torx T5 long screws.
  2. Lenovo Yoga 720 Speaker Replacement: 2 단계, 이미지 1/3 Lenovo Yoga 720 Speaker Replacement: 2 단계, 이미지 2/3 Lenovo Yoga 720 Speaker Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    구매
    • Starting from the USB port, use your opening tool to gently pry up the case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop in the order shown by the arrows.
    • Do NOT pry along the top side, or you risk damaging the casing. Stay with the arrows.
  3. Lenovo Yoga 720 Speaker Replacement: 3 단계, 이미지 1/3 Lenovo Yoga 720 Speaker Replacement: 3 단계, 이미지 2/3 Lenovo Yoga 720 Speaker Replacement: 3 단계, 이미지 3/3
    • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the case.
  4. Lenovo Yoga 720 Speaker Replacement, Battery: 4 단계, 이미지 1/3 Lenovo Yoga 720 Speaker Replacement, Battery: 4 단계, 이미지 2/3 Lenovo Yoga 720 Speaker Replacement, Battery: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    JIS Driver Set
    $19.99
    구매
    • This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
    • Be careful not to short anything on the motherboard, as the battery cannot be disconnected before removal.
    • Remove four J1 Philips screws.
    • Remove one J1 philips screw.
    • Do not mix these screws up. If you put the longer screw where the shorter screw belongs, you will damage the shield around the keyboard.
    • Lift the battery slightly using your plastic opening tool.
    • Do not lift the battery out all the way, as it is still connected to the motherboard.
    • Do NOT puncture or deform the battery or it may catch fire or even explode.
  5. Lenovo Yoga 720 Speaker Replacement: 5 단계, 이미지 1/3 Lenovo Yoga 720 Speaker Replacement: 5 단계, 이미지 2/3 Lenovo Yoga 720 Speaker Replacement: 5 단계, 이미지 3/3
    • Pull the battery towards you until the wire is accessible.
    • gently tug and wiggle on the wire until it pops out.
    • Remove the battery.
  6. Lenovo Yoga 720 Speaker Replacement, Speaker: 6 단계, 이미지 1/2 Lenovo Yoga 720 Speaker Replacement, Speaker: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    $3.99
    구매
    • Disconnect the speakers.
  7. Lenovo Yoga 720 Speaker Replacement: 7 단계, 이미지 1/3 Lenovo Yoga 720 Speaker Replacement: 7 단계, 이미지 2/3 Lenovo Yoga 720 Speaker Replacement: 7 단계, 이미지 3/3
    • Remove the left speaker.
    • Remove the Adhesive.
    • Use this pull tab to remove it.
    • Remove the right speaker,
결론
다른 5명이 해당 안내서를 완성하였습니다.
Aiden
회원 가입일: 09/19/15
17,429 평판
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 1,781
