주요 콘텐츠로 건너뛰기
Lenovo Yoga 720-12IKB Battery Replacement
필요한 것
  1. Lenovo Yoga 720-12IKB Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Unscrew and remove the four 5.5 mm Phillips #00 screws on the back panel.
  2. Lenovo Yoga 720-12IKB Battery Replacement: 2 단계, 이미지 1/1
    • Pull down on the cover to remove it and you will see the battery after removing the cover.
  3. Lenovo Yoga 720-12IKB Battery Replacement: 3 단계, 이미지 1/2 Lenovo Yoga 720-12IKB Battery Replacement: 3 단계, 이미지 2/2
    • Unscrew and remove the 4.0 mm Phillips #00 screws on the battery to remove it from the motherboard.
  4. Lenovo Yoga 720-12IKB Battery Replacement: 4 단계, 이미지 1/2 Lenovo Yoga 720-12IKB Battery Replacement: 4 단계, 이미지 2/2
    • Remove the battery wires from the socket on the motherboard above the battery.
  5. Lenovo Yoga 720-12IKB Battery Replacement: 5 단계, 이미지 1/1
    • Finally remove the battery from the case.
결론
Alex Escobar
회원 가입일: 02/10/22
778 평판
안내서 6개 작성하였습니다
Gateway, Team 1-4, Pee Spring 2022 Gateway, Team 1-4, Pee Spring 2022 회원
GCC-PEE-S22S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
I need to replace the battery in my Yoga 720-15IKB Laptop. This guide looks like it will work for me as well. Thanks.
Vaughn Berger - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 35
전체 시간: 955
