소개
If you are experiencing a loose or dirty headphone jack on your laptop then you will have to replace the headphone jack on the Lenovo 720-12IKB
The headphone jack on the Lenovo 720-12IKB is necessary to listen to the audio through a headset.
Use caution when replacing components in your Laptop as you could damage other components.
필요한 것
The headphone jack can be found on the top right of the chassis.
Start by removing the 2.0 mm Phillips #00 screw.
거의 끝나갑니다!
결론
