주요 콘텐츠로 건너뛰기
Lenovo Yoga 720-15IKB Display Replacement
필요한 것
  1. Lenovo Yoga 720-15IKB Display Replacement, Bottom Cover: 1 단계, 이미지 1/3 Lenovo Yoga 720-15IKB Display Replacement, Bottom Cover: 1 단계, 이미지 2/3 Lenovo Yoga 720-15IKB Display Replacement, Bottom Cover: 1 단계, 이미지 3/3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Display Replacement: 2 단계, 이미지 1/2 Lenovo Yoga 720-15IKB Display Replacement: 2 단계, 이미지 2/2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Display Replacement, Display: 3 단계, 이미지 1/1
    • Remove the 6, 2.5x5 screws, located on the hinges of the underside of the device.
    • Separate the display from the back panel. The display should be away from the actual computer itself.
  4. Lenovo Yoga 720-15IKB Display Replacement: 4 단계, 이미지 1/1
    • Use the opening picks and opening tool to pry off each side without cracking the display.
    • Once that is finished, carefully lift it up and place it on a safe surface.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
One Comment
This method didn't work for me. The screen is stuck to the lid with tape that has to be pulled from the bottom in order to release the screen without breaking it. I had to buy a new screen with tape.
Bruce Marcus - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 24
30일 전: 104
전체 시간: 1,614
