주요 콘텐츠로 건너뛰기
Lenovo Yoga 720-15IKB SSD Replacement
필요한 것
  1. Lenovo Yoga 720-15IKB SSD Replacement, Bottom Cover: 1 단계, 이미지 1/3 Lenovo Yoga 720-15IKB SSD Replacement, Bottom Cover: 1 단계, 이미지 2/3 Lenovo Yoga 720-15IKB SSD Replacement, Bottom Cover: 1 단계, 이미지 3/3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB SSD Replacement: 2 단계, 이미지 1/2 Lenovo Yoga 720-15IKB SSD Replacement: 2 단계, 이미지 2/2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB SSD Replacement, SSD: 3 단계, 이미지 1/1
    • Remove the one JIS #1 screw holding the SSD.
  4. Lenovo Yoga 720-15IKB SSD Replacement: 4 단계, 이미지 1/2 Lenovo Yoga 720-15IKB SSD Replacement: 4 단계, 이미지 2/2
    • Tilt the SSD away from the screw hole.
    • Pull out the SSD away from the socket it is plugged into.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jeremy Kostel
회원 가입일: 01/23/20
249 평판
안내서 2개 작성하였습니다
Cal Poly, Team S19-G3, White Winter 2020 Cal Poly, Team S19-G3, White Winter 2020 회원
CPSU-WHITE-W20S19G3
4 회원들
안내서 25개 작성하였습니다
댓글 한 개
The M.2 drive shown as a replacement part, at the time I replaced mine, was an Corsair M.2 drive with a SATA interface. My machine would not boot with this drive. I looked up the original drive on the internet and it was an Intel M.2 NVMe drive. I bought a new M.2 NVMe drive and it works find. I guess the disk controller in my laptop does not recognize the M.2 with a SATA interface. Maybe something they changed in the middle of the product line. Anyway be sure to check which drive you have before you buy the replacement. Rest of the information great.
John Pritchard - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 17
30일 전: 79
전체 시간: 3,996
