주요 콘텐츠로 건너뛰기
Lenovo Yoga 720-15IKB Wireless Adapter Replacement
필요한 것
  1. Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: 1 단계, 이미지 1/3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: 1 단계, 이미지 2/3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: 1 단계, 이미지 3/3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: 2 단계, 이미지 1/2 Lenovo Yoga 720-15IKB Wireless Adapter Replacement: 2 단계, 이미지 2/2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: 3 단계, 이미지 1/3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: 3 단계, 이미지 2/3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: 3 단계, 이미지 3/3
    • Lift the foam covering the connecting wires and screw, and use the Phillips #0 screwdriver to remove the 2mm screw.
  4. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: 4 단계, 이미지 1/1
    • Grab the adapter from both sides and pull towards the hinge to remove the adapter from the device.
  5. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: 5 단계, 이미지 1/1
    • Remove the black and white wires from the adapter by pulling up on each wire.
    • When reassembling, make sure to press each wire connector firmly onto the new adapter to make sure it is a secure fit.
결론
Matthew Bornhorst
회원 가입일: 01/23/20
420 평판
안내서 2개 작성하였습니다
Cal Poly, Team S19-G3, White Winter 2020 Cal Poly, Team S19-G3, White Winter 2020 회원
CPSU-WHITE-W20S19G3
4 회원들
안내서 22개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 518
