주요 콘텐츠로 건너뛰기
Lenovo Yoga 730-13IKB Back Case Replacement
필요한 것
  1. Lenovo Yoga 730-13IKB Back Case Replacement, Back Case: 1 단계, 이미지 1/3 Lenovo Yoga 730-13IKB Back Case Replacement, Back Case: 1 단계, 이미지 2/3 Lenovo Yoga 730-13IKB Back Case Replacement, Back Case: 1 단계, 이미지 3/3
    • Power off the laptop and place it facedown on a non-scratching surface.
    • Remove the nine T5 screws fastening the back case.
  2. Lenovo Yoga 730-13IKB Back Case Replacement: 2 단계, 이미지 1/3 Lenovo Yoga 730-13IKB Back Case Replacement: 2 단계, 이미지 2/3 Lenovo Yoga 730-13IKB Back Case Replacement: 2 단계, 이미지 3/3
    • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
    • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
    • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
  3. Lenovo Yoga 730-13IKB Back Case Replacement: 3 단계, 이미지 1/1
    • Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
    • Go slowly to avoid breaking any connecting tabs.
결론
Colin Reay
회원 가입일: 01/23/20
848 평판
안내서 5개 작성하였습니다
Cal Poly, Team S1-G1, White Winter 2020 Cal Poly, Team S1-G1, White Winter 2020 회원
CPSU-WHITE-W20S1G1
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 28
전체 시간: 1,929
