주요 콘텐츠로 건너뛰기
Lenovo Yoga 730-13IKB Heat Sink Replacement
필요한 것
  1. Lenovo Yoga 730-13IKB Heat Sink Replacement, Back Case: 1 단계, 이미지 1/3 Lenovo Yoga 730-13IKB Heat Sink Replacement, Back Case: 1 단계, 이미지 2/3 Lenovo Yoga 730-13IKB Heat Sink Replacement, Back Case: 1 단계, 이미지 3/3
    • Power off the laptop and place it facedown on a non-scratching surface.
    • Remove the nine T5 screws fastening the back case.
  2. Lenovo Yoga 730-13IKB Heat Sink Replacement: 2 단계, 이미지 1/3 Lenovo Yoga 730-13IKB Heat Sink Replacement: 2 단계, 이미지 2/3 Lenovo Yoga 730-13IKB Heat Sink Replacement: 2 단계, 이미지 3/3
    • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
    • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
    • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
  3. Lenovo Yoga 730-13IKB Heat Sink Replacement: 3 단계, 이미지 1/1
    • Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
    • Go slowly to avoid breaking any connecting tabs.
  4. Lenovo Yoga 730-13IKB Heat Sink Replacement, Heat Sink: 4 단계, 이미지 1/2 Lenovo Yoga 730-13IKB Heat Sink Replacement, Heat Sink: 4 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the eight 2.5mm screws securing the heat sink assembly.
  5. Lenovo Yoga 730-13IKB Heat Sink Replacement: 5 단계, 이미지 1/2 Lenovo Yoga 730-13IKB Heat Sink Replacement: 5 단계, 이미지 2/2
    • Release the fan connector by gently pushing the gray locking tab up using a plastic spudger. Do this for both of the fans.
    • Pull each fan cable straight out of the connector.
  6. Lenovo Yoga 730-13IKB Heat Sink Replacement: 6 단계, 이미지 1/1
    • Remove the heat sink assembly by holding the middle plate and rotating the assembly down towards the back of the motherboard.
    • Pull the heat sink diagonally away from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Colin Reay
회원 가입일: 01/23/20
848 평판
안내서 5개 작성하였습니다
Cal Poly, Team S1-G1, White Winter 2020 Cal Poly, Team S1-G1, White Winter 2020 회원
CPSU-WHITE-W20S1G1
3 회원들
안내서 14개 작성하였습니다
댓글 한 개
gdje i kako kupiti hladnjak za lenovo yoga 730-13 sa zamjenu
Smajo Avdic - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 992
