주요 콘텐츠로 건너뛰기
Lenovo Yoga 910-13IKB Fan Replacement
필요한 것
  1. Lenovo Yoga 910-13IKB Fan Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo Yoga 910-13IKB Fan Replacement, Back Panel: 1 단계, 이미지 2/2
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Fan Replacement, Battery: 2 단계, 이미지 1/1
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Fan Replacement: 3 단계, 이미지 1/3 Lenovo Yoga 910-13IKB Fan Replacement: 3 단계, 이미지 2/3 Lenovo Yoga 910-13IKB Fan Replacement: 3 단계, 이미지 3/3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  4. Lenovo Yoga 910-13IKB Fan Replacement, Fan: 4 단계, 이미지 1/2 Lenovo Yoga 910-13IKB Fan Replacement, Fan: 4 단계, 이미지 2/2
    • Remove the screws attached to the SSD stick by using a Phillips #0 screwdriver.
    • Pull the SSD stick directly to the right until it shifts out of place to remove it.
  5. Lenovo Yoga 910-13IKB Fan Replacement: 5 단계, 이미지 1/3 Lenovo Yoga 910-13IKB Fan Replacement: 5 단계, 이미지 2/3 Lenovo Yoga 910-13IKB Fan Replacement: 5 단계, 이미지 3/3
    • Lift the labeled flap seal and remove the ribbon cable that connects the USB ports to the motherboard and gently pull away.
    • Be gentle when detaching the cables, the attachment port is easy to damage.
  6. Lenovo Yoga 910-13IKB Fan Replacement: 6 단계, 이미지 1/3 Lenovo Yoga 910-13IKB Fan Replacement: 6 단계, 이미지 2/3 Lenovo Yoga 910-13IKB Fan Replacement: 6 단계, 이미지 3/3
    • Unscrew the single 1 mm screw at the left of Wi-Fi card with a Phillips #0 screwdriver.
    • Remove the Wi-Fi card by gently pulling the card to the left.
  7. Lenovo Yoga 910-13IKB Fan Replacement: 7 단계, 이미지 1/3 Lenovo Yoga 910-13IKB Fan Replacement: 7 단계, 이미지 2/3 Lenovo Yoga 910-13IKB Fan Replacement: 7 단계, 이미지 3/3
    • Unscrew three 1 mm screws on the rightmost USB port board using a Phillips #0 screwdriver.
    • Remove the rightmost USB port board by pulling it up and out.
  8. Lenovo Yoga 910-13IKB Fan Replacement: 8 단계, 이미지 1/3 Lenovo Yoga 910-13IKB Fan Replacement: 8 단계, 이미지 2/3 Lenovo Yoga 910-13IKB Fan Replacement: 8 단계, 이미지 3/3
    • Unscrew the four 1 mm screws on the leftmost USB port using a Phillips #0 screwdriver.
    • Remove the leftmost USB port board by pulling it up and out.
  9. Lenovo Yoga 910-13IKB Fan Replacement: 9 단계, 이미지 1/2 Lenovo Yoga 910-13IKB Fan Replacement: 9 단계, 이미지 2/2
    • Remove seven 1 mm screws from the motherboard using a Phillips #0 screwdriver.
  10. Lenovo Yoga 910-13IKB Fan Replacement: 10 단계, 이미지 1/2 Lenovo Yoga 910-13IKB Fan Replacement: 10 단계, 이미지 2/2
    • Gently pull the Back Connector strip towards you, this will safely disconnect it.
    • Disconnect the two Upper Connector Strips by using Tweezers and unclipping the upper tab.
    • Be cautious not to rip the strips or parts.
  11. Lenovo Yoga 910-13IKB Fan Replacement: 11 단계, 이미지 1/3 Lenovo Yoga 910-13IKB Fan Replacement: 11 단계, 이미지 2/3 Lenovo Yoga 910-13IKB Fan Replacement: 11 단계, 이미지 3/3
    • Gently peel up the sticky adhesive attaching the fan to the hinge.
    • Be very careful with the ports when removing to not damage anything else.
  12. Lenovo Yoga 910-13IKB Fan Replacement: 12 단계, 이미지 1/2 Lenovo Yoga 910-13IKB Fan Replacement: 12 단계, 이미지 2/2
    • Remove the motherboard and fan by pulling away and up from the hinge.
  13. Lenovo Yoga 910-13IKB Fan Replacement: 13 단계, 이미지 1/2 Lenovo Yoga 910-13IKB Fan Replacement: 13 단계, 이미지 2/2
    • Flip the component to the opposite side.
  14. Lenovo Yoga 910-13IKB Fan Replacement: 14 단계, 이미지 1/2 Lenovo Yoga 910-13IKB Fan Replacement: 14 단계, 이미지 2/2
    • Remove three 1 mm screws using a Phillips #0 screwdriver.
  15. Lenovo Yoga 910-13IKB Fan Replacement: 15 단계, 이미지 1/2 Lenovo Yoga 910-13IKB Fan Replacement: 15 단계, 이미지 2/2
    • Lift the leftmost flap seal up and remove the connector strip.
    • Lift the two right flap seals up and remove the connector strip.
    • Using tweezers or a spudger may be helpful.
  16. Lenovo Yoga 910-13IKB Fan Replacement: 16 단계, 이미지 1/1
    • Lift the fan component upward and away from the motherboard.
결론
To reassemble your device, follow steps 1-8 in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Angel L Appelzoller
회원 가입일: 01/18/22
223 평판
안내서 1개 작성함
댓글 한 개
This laptop throttles like crazy with heavy load even if both fans are working perfectly!
danwat1234 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 37
전체 시간: 1,264
