주요 콘텐츠로 건너뛰기
Lenovo Yoga 910-13IKB Wi-Fi Card Replacement
필요한 것
  1. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Back Panel: 1 단계, 이미지 2/2
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Battery: 2 단계, 이미지 1/1
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: 3 단계, 이미지 1/3 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: 3 단계, 이미지 2/3 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: 3 단계, 이미지 3/3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  4. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 1/1
    • Remove the single 1 mm screw at left of Wi-Fi card with a Phillips #0 screwdriver.
  5. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: 5 단계, 이미지 1/2 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: 5 단계, 이미지 2/2
    • Pull the Wi-Fi card out of the slot on the motherboard.
    • It is still connected to the coaxial cables so don't yank it out or those connections will break.
  6. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: 6 단계, 이미지 1/3 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: 6 단계, 이미지 2/3 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: 6 단계, 이미지 3/3
    • Detach the white wire that is connected to the Wi-Fi card by applying gentle pressure.
    • Detach the black wire by applying gentle pressure.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tyler Jane McClure
회원 가입일: 01/18/22
123 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 20
전체 시간: 498
