주요 콘텐츠로 건너뛰기
소개
This guide shows how to properly remove the back cover from the Lenovo Yoga 920-13IKB.
  1. Flip the device over to access the screws on the back cover. Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Slide the iFixit Opening Tool under the back cover to lift it up. Pull up on the cover with your hand to release the tab holding the center of the cover in place. Pull up on the cover with your hand to release the tab holding the center of the cover in place.
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alyssa McCulloch
회원 가입일: 2019년 01월 24일
1,539 평판
안내서 9개 작성하였습니다
Cal Poly, Team S2-G3, White Winter 2019 Cal Poly, Team S2-G3, White Winter 2019 회원
CPSU-WHITE-W19S2G3
4 회원들
안내서 27개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 34
전체 시간: 1,589
