주요 콘텐츠로 건너뛰기
Lenovo Yoga 920-13IKB Battery Replacement
필요한 것
  1. Lenovo Yoga 920-13IKB Battery Replacement, Back Cover: 1 단계, 이미지 1/2 Lenovo Yoga 920-13IKB Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB Battery Replacement: 2 단계, 이미지 1/3 Lenovo Yoga 920-13IKB Battery Replacement: 2 단계, 이미지 2/3 Lenovo Yoga 920-13IKB Battery Replacement: 2 단계, 이미지 3/3
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB Battery Replacement, Battery: 3 단계, 이미지 1/3 Lenovo Yoga 920-13IKB Battery Replacement, Battery: 3 단계, 이미지 2/3 Lenovo Yoga 920-13IKB Battery Replacement, Battery: 3 단계, 이미지 3/3
    • Remove the four 5mm Phillips #00 screws that hold the battery in place.
  4. Lenovo Yoga 920-13IKB Battery Replacement: 4 단계, 이미지 1/2 Lenovo Yoga 920-13IKB Battery Replacement: 4 단계, 이미지 2/2
    • Grab the grouping of wires with your fingers close to the connector and gently pull to disconnect the battery from the motherboard.
    • The wire grouping is located underneath the thin flap near the center of the battery.
    • Do not lift the battery out before disconnection from the motherboard to prevent shortages or damage.
  5. Lenovo Yoga 920-13IKB Battery Replacement: 5 단계, 이미지 1/1
    • Use the iFixit Opening Tool to lift the battery up enough to grab it with your hands.
  6. Lenovo Yoga 920-13IKB Battery Replacement: 6 단계, 이미지 1/1
    • Remove the battery.
결론
다른 29명이 해당 안내서를 완성하였습니다.
Alyssa McCulloch
회원 가입일: 01/24/19
1,906 평판
안내서 9개 작성하였습니다
Cal Poly, Team S2-G3, White Winter 2019 Cal Poly, Team S2-G3, White Winter 2019 회원
CPSU-WHITE-W19S2G3
4 회원들
안내서 29개 작성하였습니다
댓글 13개
What is the correct replacement battery for this device?
Stephen Prather - 답글
Simple, a real simple straight forward process with the right tools of course. Thanks
Daniel Smith - 답글
Thank you, was very easy replace battery using your guide!
Andrejs - 답글
Simple and easy. Great guide to! Thanks so much
Isaac Stahl - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 79
30일 전: 367
전체 시간: 23,759
