주요 콘텐츠로 건너뛰기
Lenovo Yoga 920-13IKB Screen Replacement
필요한 것
  1. Lenovo Yoga 920-13IKB Screen Replacement, Screen: 1 단계, 이미지 1/3 Lenovo Yoga 920-13IKB Screen Replacement, Screen: 1 단계, 이미지 2/3 Lenovo Yoga 920-13IKB Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Rotate the device into tablet mode so the device’s screen is facing up.
  2. Lenovo Yoga 920-13IKB Screen Replacement: 2 단계, 이미지 1/3 Lenovo Yoga 920-13IKB Screen Replacement: 2 단계, 이미지 2/3 Lenovo Yoga 920-13IKB Screen Replacement: 2 단계, 이미지 3/3
    • Pry the metal cover up from the bottom of the screen with the iFixit Opening Tool to reveal the corners of the white adhesive strip.
    • Pull the metal cover off the device until it's completely free.
    • Clean off the old adhesive and straighten the metal cover when reassembling.
    • Use a new adhesive when reassembling.
    • Avoid bending the metal cover to prevent damage to the device.
    • If you’re really struggling, you may pry from the opposite side, but be careful not to damage the screen or metal cover.
  3. Lenovo Yoga 920-13IKB Screen Replacement: 3 단계, 이미지 1/2 Lenovo Yoga 920-13IKB Screen Replacement: 3 단계, 이미지 2/2
    • Remove the eight 3mm Phillips #000 screws that were below the metal cover to loosen the screen.
  4. Lenovo Yoga 920-13IKB Screen Replacement: 4 단계, 이미지 1/3 Lenovo Yoga 920-13IKB Screen Replacement: 4 단계, 이미지 2/3 Lenovo Yoga 920-13IKB Screen Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Pull out the white adhesives using the iFixit Tweezers.
    • Roll the tape around the iFixit Tweezers to remove successfully.
  5. Lenovo Yoga 920-13IKB Screen Replacement: 5 단계, 이미지 1/1
    • Pry up the screen with the iFixit Opening Tool.
  6. Lenovo Yoga 920-13IKB Screen Replacement: 6 단계, 이미지 1/2 Lenovo Yoga 920-13IKB Screen Replacement: 6 단계, 이미지 2/2
    • Lift the screen with your hands and place the the screen face down, keeping the device in the same location.
  7. Lenovo Yoga 920-13IKB Screen Replacement: 7 단계, 이미지 1/1
    • Flip up the black tab on the connector at the top of the screen with the iFixit Opening Tool.
  8. Lenovo Yoga 920-13IKB Screen Replacement: 8 단계, 이미지 1/1
    • Use the iFixit Tweezers to remove the ribbon cable from the connector.
  9. Lenovo Yoga 920-13IKB Screen Replacement: 9 단계, 이미지 1/1
    • Flip up the black tab on the smallest connector at the bottom of the screen with the iFixit Opening Tool.
  10. Lenovo Yoga 920-13IKB Screen Replacement: 10 단계, 이미지 1/1
  11. Lenovo Yoga 920-13IKB Screen Replacement: 11 단계, 이미지 1/1
    • Flip up the thick black cable at the bottom of the screen with your thumb.
    • Use the iFixit Opening Tool to lift up the brass tab to free up the cable.
  12. Lenovo Yoga 920-13IKB Screen Replacement: 12 단계, 이미지 1/1
    • Remove the ribbon cable from the connector to detach the screen from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alyssa McCulloch
회원 가입일: 01/24/19
1,906 평판
안내서 9개 작성하였습니다
Cal Poly, Team S2-G3, White Winter 2019 Cal Poly, Team S2-G3, White Winter 2019 회원
CPSU-WHITE-W19S2G3
4 회원들
안내서 29개 작성하였습니다
댓글 5개
Does this also appy to the Yoga 910-13IBK?
Tony Salazar - 답글
Alyssa, I am about to tackle this job to replace a cracked screen - I greatly appreciate your guide. In step 2 you recommend using new adhesive. What adhesive is recommended exactly?
Bradley Buege - 답글
See this youtube video from Lenovo on LCD tape, how to find what kind, how to remove it, and how to reapply it.
https://www.youtube.com/watch?v=EeUM312_...
Robert -
You missed the camera transfer step. I completed the screen replacement only to find no camera for Zoom. Then realized the this procedure didn’t cover the camera transfer.
ddurbin1 - 답글
Ok, 15 minutes to complete this is ridiculous. A seasoned person couldn't do this in 15 minutes, especially when removing and replacing adhesive, etc. That must be a typo.
Syber Geek - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 36
전체 시간: 5,563
