주요 콘텐츠로 건너뛰기
Lenovo Yoga 920-13IKB USB - C Port Replacement
필요한 것
  1. Lenovo Yoga 920-13IKB USB - C Port Replacement, Back Cover: 1 단계, 이미지 1/2 Lenovo Yoga 920-13IKB USB - C Port Replacement, Back Cover: 1 단계, 이미지 2/2
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB USB - C Port Replacement: 2 단계, 이미지 1/3 Lenovo Yoga 920-13IKB USB - C Port Replacement: 2 단계, 이미지 2/3 Lenovo Yoga 920-13IKB USB - C Port Replacement: 2 단계, 이미지 3/3
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB USB - C Port Replacement, Motherboard: 3 단계, 이미지 1/2 Lenovo Yoga 920-13IKB USB - C Port Replacement, Motherboard: 3 단계, 이미지 2/2
    • Remove the twelve 5mm Phillips #00 screws to loosen the motherboard.
  4. Lenovo Yoga 920-13IKB USB - C Port Replacement: 4 단계, 이미지 1/3 Lenovo Yoga 920-13IKB USB - C Port Replacement: 4 단계, 이미지 2/3 Lenovo Yoga 920-13IKB USB - C Port Replacement: 4 단계, 이미지 3/3
    • Flip up the ten flat connectors holding the motherboard using the iFixit Opening Tool to free the motherboard.
  5. Lenovo Yoga 920-13IKB USB - C Port Replacement: 5 단계, 이미지 1/2 Lenovo Yoga 920-13IKB USB - C Port Replacement: 5 단계, 이미지 2/2
    • Pull out the ribbon cables from the opened connectors using the iFixit Tweezers to free up the motherboard.
  6. Lenovo Yoga 920-13IKB USB - C Port Replacement: 6 단계, 이미지 1/2 Lenovo Yoga 920-13IKB USB - C Port Replacement: 6 단계, 이미지 2/2
    • Disconnect the battery by pulling the ribbon wire grouping out of the top of the motherboard.
  7. Lenovo Yoga 920-13IKB USB - C Port Replacement: 7 단계, 이미지 1/2 Lenovo Yoga 920-13IKB USB - C Port Replacement: 7 단계, 이미지 2/2
    • Disconnect the red and black wire from the motherboard using the iFixit Tweezers.
  8. Lenovo Yoga 920-13IKB USB - C Port Replacement: 8 단계, 이미지 1/3 Lenovo Yoga 920-13IKB USB - C Port Replacement: 8 단계, 이미지 2/3 Lenovo Yoga 920-13IKB USB - C Port Replacement: 8 단계, 이미지 3/3
    • Lift the motherboard up parallel to the hinge of the device.
    • Gently pull away from the port cutouts of the USB-C and audio jack to remove the motherboard from the device casing.
    • Avoid pulling the motherboard all the way out until the green AC card is disconnected.
  9. Lenovo Yoga 920-13IKB USB - C Port Replacement: 9 단계, 이미지 1/3 Lenovo Yoga 920-13IKB USB - C Port Replacement: 9 단계, 이미지 2/3 Lenovo Yoga 920-13IKB USB - C Port Replacement: 9 단계, 이미지 3/3
    • Disconnect the green AC card plugged into the motherboard by pulling it out with your hands.
  10. Lenovo Yoga 920-13IKB USB - C Port Replacement: 10 단계, 이미지 1/1
    • Flip the motherboard over to access the back side.
  11. Lenovo Yoga 920-13IKB USB - C Port Replacement: 11 단계, 이미지 1/3 Lenovo Yoga 920-13IKB USB - C Port Replacement: 11 단계, 이미지 2/3 Lenovo Yoga 920-13IKB USB - C Port Replacement: 11 단계, 이미지 3/3
    • Remove four 3mm JIS #00 screws with the screwdriver.
    • Remove one 3mm Phillips #00 screw with the screwdriver.
    • The screws stay attached to the speaker when removed from the motherboard.
  12. Lenovo Yoga 920-13IKB USB - C Port Replacement: 12 단계, 이미지 1/1
    • Separate the fans from the motherboard to isolate it for replacement.
  13. Lenovo Yoga 920-13IKB USB - C Port Replacement, USB - C Port: 13 단계, 이미지 1/1
    • Replace the motherboard to replace the USB-C ports.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Alyssa McCulloch
회원 가입일: 01/24/19
1,906 평판
안내서 9개 작성하였습니다
Cal Poly, Team S2-G3, White Winter 2019 Cal Poly, Team S2-G3, White Winter 2019 회원
CPSU-WHITE-W19S2G3
4 회원들
안내서 29개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 18
30일 전: 58
전체 시간: 6,104
