주요 콘텐츠로 건너뛰기
Lenovo Yoga 920-13IKB USB 3.0 Port Replacement
필요한 것
  1. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement, Back Cover: 1 단계, 이미지 1/2 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement, Back Cover: 1 단계, 이미지 2/2
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: 2 단계, 이미지 1/3 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: 2 단계, 이미지 2/3 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: 2 단계, 이미지 3/3
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement, USB 3.0 Port: 3 단계, 이미지 1/2 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement, USB 3.0 Port: 3 단계, 이미지 2/2
    • Disconnect the red and black wire connected to the speaker using the iFixit Tweezers.
  4. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: 4 단계, 이미지 1/1
    • Lift up the black tab on the flat cable connector with the iFixit Opening Tool.
  5. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: 5 단계, 이미지 1/3 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: 5 단계, 이미지 2/3 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: 5 단계, 이미지 3/3
    • Flip up the tab using the iFixit Tweezers to release the flat cable.
  6. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: 6 단계, 이미지 1/2 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: 6 단계, 이미지 2/2
    • Undo the two 3mm Phillips #00 screws to loosen the USB 3.0 board.
  7. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: 7 단계, 이미지 1/3 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: 7 단계, 이미지 2/3 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: 7 단계, 이미지 3/3
    • Remove the USB 3.0 Board from the device using the iFixit Opening Tool.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Alyssa McCulloch
회원 가입일: 01/24/19
1,906 평판
안내서 9개 작성하였습니다
Cal Poly, Team S2-G3, White Winter 2019 Cal Poly, Team S2-G3, White Winter 2019 회원
CPSU-WHITE-W19S2G3
4 회원들
안내서 29개 작성하였습니다
댓글 한 개
Just wanted to say thank you to Alyssa and the others who contributed to this.
I just used your guide to fix a problem with my Yoga constantly entering and waking (repeatedly, seconds apart) from connected sleep mode. Infuriating. It was accompanied by the USB connect/disconnect sound as well.
Using the Event Viewer I managed to find out it was entering sleep mode in response to the power button (which I wasn’t pressing). So, I used your guide to disconnect and reconnect the USB board and it has resolved my issue.
iFixIt gained some tools income, you gained some more reputation points, and I gained a laptop that’s behaving itself now!
Now, what else can I break? ;o)
Sean Puffett - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 2,034
