주요 콘텐츠로 건너뛰기
Lenovo Yoga C930-13IKB Back Cover Replacement
필요한 것
  1. Lenovo Yoga C930-13IKB Back Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Back Cover Replacement: 2 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Back Cover Replacement: 2 단계, 이미지 2/2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Back Cover Replacement: 3 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Back Cover Replacement: 3 단계, 이미지 2/2
    • Carefully lift the cover off with your hands.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Hanna Lazkani
회원 가입일: 01/23/20
788 평판
안내서 3개 작성하였습니다
Cal Poly, Team S19-G5, White Winter 2020 Cal Poly, Team S19-G5, White Winter 2020 회원
CPSU-WHITE-W20S19G5
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 58
전체 시간: 2,675
