주요 콘텐츠로 건너뛰기
Lenovo Yoga C930-13IKB Speaker Replacement
필요한 것
  1. Lenovo Yoga C930-13IKB Speaker Replacement, Back Cover: 1 단계, 이미지 1/1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Speaker Replacement: 2 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Speaker Replacement: 2 단계, 이미지 2/2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Speaker Replacement: 3 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Speaker Replacement: 3 단계, 이미지 2/2
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB Speaker Replacement, Battery: 4 단계, 이미지 1/3 Lenovo Yoga C930-13IKB Speaker Replacement, Battery: 4 단계, 이미지 2/3 Lenovo Yoga C930-13IKB Speaker Replacement, Battery: 4 단계, 이미지 3/3
    • Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
    • Use the spudger for assistance.
  5. Lenovo Yoga C930-13IKB Speaker Replacement: 5 단계, 이미지 1/1
    • Unscrew the four 3mm screws with a Phillips screwdriver.
  6. Lenovo Yoga C930-13IKB Speaker Replacement: 6 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Speaker Replacement: 6 단계, 이미지 2/2
    • The battery is still held in place with two stretch-release adhesive strips, similar to ones found in an iPhone.
    • Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
    • Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
    • Repeat the procedure for the second strip on the opposite side of the battery.
    • Be careful not to bend the battery. Breaking the battery is dangerous.
    • Remove the battery with your hands.
  7. Lenovo Yoga C930-13IKB Speaker Replacement, Speakers: 7 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Speaker Replacement, Speakers: 7 단계, 이미지 2/2
    • Remove the four 2mm screws that attach the speakers to the laptop body using a Phillips #00 screwdriver.
  8. Lenovo Yoga C930-13IKB Speaker Replacement: 8 단계, 이미지 1/3 Lenovo Yoga C930-13IKB Speaker Replacement: 8 단계, 이미지 2/3 Lenovo Yoga C930-13IKB Speaker Replacement: 8 단계, 이미지 3/3
    • Gently unplug the connector using two fingers.
    • Use an opening tool if needed.
  9. Lenovo Yoga C930-13IKB Speaker Replacement: 9 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Speaker Replacement: 9 단계, 이미지 2/2
    • Lift the black wire that connects the speakers to the motherboard from its track using an opening tool.
    • Press the wire down firmly and in the right track when reassembling.
  10. Lenovo Yoga C930-13IKB Speaker Replacement: 10 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Speaker Replacement: 10 단계, 이미지 2/2
    • Remove the right speaker using your fingers.
    • Remove the left speaker, which is connected to the right speaker by the black and red wire.
    • When reassembling, make sure the black and red wire is in the right track so that you are able to put the back cover back without wire poking out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Andrew Walker
회원 가입일: 01/23/20
166 평판
안내서 1개 작성함
Cal Poly, Team S19-G5, White Winter 2020 Cal Poly, Team S19-G5, White Winter 2020 회원
CPSU-WHITE-W20S19G5
4 회원들
안내서 16개 작성하였습니다
댓글 한 개
What would be the additional steps to replace a right hinge as the speakers are in the hinge?
Brian Dernbach - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 10
전체 시간: 754
