주요 콘텐츠로 건너뛰기
Lenovo Yoga C930-13IKB Touch Pad Replacement
필요한 것
  1. Lenovo Yoga C930-13IKB Touch Pad Replacement, Back Cover: 1 단계, 이미지 1/1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Touch Pad Replacement: 2 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Touch Pad Replacement: 2 단계, 이미지 2/2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Touch Pad Replacement: 3 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Touch Pad Replacement: 3 단계, 이미지 2/2
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB Touch Pad Replacement, Battery: 4 단계, 이미지 1/3 Lenovo Yoga C930-13IKB Touch Pad Replacement, Battery: 4 단계, 이미지 2/3 Lenovo Yoga C930-13IKB Touch Pad Replacement, Battery: 4 단계, 이미지 3/3
    • Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
    • Use the spudger for assistance.
  5. Lenovo Yoga C930-13IKB Touch Pad Replacement: 5 단계, 이미지 1/1
    • Unscrew the four 3mm screws with a Phillips screwdriver.
  6. Lenovo Yoga C930-13IKB Touch Pad Replacement: 6 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Touch Pad Replacement: 6 단계, 이미지 2/2
    • The battery is still held in place with two stretch-release adhesive strips, similar to ones found in an iPhone.
    • Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
    • Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
    • Repeat the procedure for the second strip on the opposite side of the battery.
    • Be careful not to bend the battery. Breaking the battery is dangerous.
    • Remove the battery with your hands.
  7. Lenovo Yoga C930-13IKB Touch Pad Replacement, Touch Pad: 7 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Touch Pad Replacement, Touch Pad: 7 단계, 이미지 2/2
    • Unscrew the four 2 mm screws with a Phillips #00 screwdriver.
  8. Lenovo Yoga C930-13IKB Touch Pad Replacement: 8 단계, 이미지 1/3 Lenovo Yoga C930-13IKB Touch Pad Replacement: 8 단계, 이미지 2/3 Lenovo Yoga C930-13IKB Touch Pad Replacement: 8 단계, 이미지 3/3
    • Carefully pull out the small electrical wire from the back of the touch pad.
  9. Lenovo Yoga C930-13IKB Touch Pad Replacement: 9 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Touch Pad Replacement: 9 단계, 이미지 2/2
    • The touch pad must be slid out before being lifted out.
    • Lift up the touch pad.
    • Slide the touch pad out of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matteo
회원 가입일: 01/23/20
97 평판
안내서 1개 작성함
Cal Poly, Team S19-G5, White Winter 2020 Cal Poly, Team S19-G5, White Winter 2020 회원
CPSU-WHITE-W20S19G5
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 13
전체 시간: 822
