주요 콘텐츠로 건너뛰기
Lenovo Yoga C930-13IKB Wi-Fi Card Replacement
필요한 것
  1. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement, Back Cover: 1 단계, 이미지 1/1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 2 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 2 단계, 이미지 2/2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 3 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 3 단계, 이미지 2/2
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 2/2
    • Find the Wi-Fi card located on the right just above the battery. It is a green chip with a white label that says "Intel 9260" somewhere on it.
  5. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 5 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 5 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the single 2 mm screw that attaches the card to the motherboard.
  6. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 6 단계, 이미지 1/3 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 6 단계, 이미지 2/3 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    구매
    • Gently pull or use the iFixit opening tool to detach the black and white wires from the card.
    • When reassembling, these wires are difficult to reattach, so be patient. Line the wires up with your fingers and press down on the connections with the opening tool.
  7. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 7 단계, 이미지 1/2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 7 단계, 이미지 2/2
    • Pinch the card on either side and pull to the right to unplug it from the motherboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jessie Boucher
회원 가입일: 01/23/20
289 평판
안내서 1개 작성함
Cal Poly, Team S19-G5, White Winter 2020 Cal Poly, Team S19-G5, White Winter 2020 회원
CPSU-WHITE-W20S19G5
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 26
전체 시간: 1,372
