주요 콘텐츠로 건너뛰기
Lenovo Yoga Tab 3 10 Wifi Module Replacement
필요한 것
  1. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Back Cover: 1 단계, 이미지 1/1
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3 10 Wifi Module Replacement: 2 단계, 이미지 1/3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: 2 단계, 이미지 2/3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: 2 단계, 이미지 3/3
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
    On 3 plus model the third screw is not under microSD card but rather under a small sticker on the right side. Plus has longer battery.
    George - 답글
    on the Tab 3 plus , the third screw is not under the sd card but a little further over under another sticker and is painted white
    dan o brien - 답글
  3. Lenovo Yoga Tab 3 10 Wifi Module Replacement: 3 단계, 이미지 1/3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: 3 단계, 이미지 2/3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: 3 단계, 이미지 3/3
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
    On some models there is glue pad under the sim/sdcard tray.
    Ervins Stepanovs - 답글
    Ein Hinweis auf den Federrahmen an der Kamera wäre nützlich. Er ist sehr empfindlich. Ich habe ihn beim Öffnen zerstört und jetzt stellt die Kamera nicht mehr scharf.
    Thomas Spieker - 답글
    Hallo Thomas, tut mir leid, dass deine Kamera nicht mehr schart stellt. Aber die Anleitungen funktionieren wie Wikipedia: Wenn du mehr Infos hast, stelle sie gern allen anderen zur Verfügung!
    Fabian Neidhardt -
    (at least on the Plus model) the most difficult plastic clips are near the micro-SD/SIM. So it is easier to release the other side, where the camera not is. or pull the casing "down" towards the battery/stand.
    Hans Wurst - 답글
  4. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: 4 단계, 이미지 1/2 Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: 4 단계, 이미지 2/2
    • Use the nylon spudger to gently lift the foil cover of the wifi model.
  5. Lenovo Yoga Tab 3 10 Wifi Module Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to gently lift the gold tape located above the copper foil.
  6. Lenovo Yoga Tab 3 10 Wifi Module Replacement: 6 단계, 이미지 1/1
    • Use the plastic spudger to disconnect the wifi module connector from the motherboard.
  7. Lenovo Yoga Tab 3 10 Wifi Module Replacement: 7 단계, 이미지 1/2 Lenovo Yoga Tab 3 10 Wifi Module Replacement: 7 단계, 이미지 2/2
    • Carefully lift the wifi module from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Phanudej
회원 가입일: 02/20/17
1,184 평판
안내서 5개 작성하였습니다
USF Tampa, Team S3-G2, Sullivan Spring 2017 USF Tampa, Team S3-G2, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S3G2
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
where can i buy this type of module?
rebeca rackolavsci - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 34
전체 시간: 3,471
