주요 콘텐츠로 건너뛰기
Lenovo Yoga Tab 3 8 Back Cover Replacement
필요한 것
  1. Lenovo Yoga Tab 3 8 Back Cover Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Lenovo Yoga Tab 3 8 Back Cover Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Lenovo Yoga Tab 3 8 Back Cover Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Open the kickstand by pressing the release button in the center.
    • Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
  2. Lenovo Yoga Tab 3 8 Back Cover Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the three 2mm screws under the kickstand with a PH00 screwdriver.
    • The third 2mm screw to the right may have an S sticker covering it which you can scrape off.
  3. Lenovo Yoga Tab 3 8 Back Cover Replacement: 3 단계, 이미지 3개 중 1개 Lenovo Yoga Tab 3 8 Back Cover Replacement: 3 단계, 이미지 3개 중 2개 Lenovo Yoga Tab 3 8 Back Cover Replacement: 3 단계, 이미지 3개 중 3개
    • Starting along the edge opposite of the hinge, insert a plastic opening tool between the screen and the backing to begin separating the small clips holding the backing on.
    • Work along the edge and then up the sides, separating the clips with the plastic opening tool.
    • There is adhesive underneath the slot for the SD card so you will need to slowly apply some force to break the adhesive.
    • As the back is separated from the device, be careful to not lose the power button. It may come loose and fall out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Nicklaus Krems
회원 가입일: 09/25/17
1,073 평판
안내서 8개를 작성함
USF Tampa, Team S16-G2, Eyestone Fall 2017 USF Tampa, Team S16-G2, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S16G2
4 회원들
안내서 16개를 작성함
1가이드 댓글
Had put the SIM in the Memory card slot, instructions came in handy.
Brijesh Rajashekara - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 15
전체 시간: 3,141
