주요 콘텐츠로 건너뛰기
Lenovo Yoga Tab 3 8 Wifi Module Replacement
필요한 것
  1. Lenovo Yoga Tab 3 8 Wifi Module Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Lenovo Yoga Tab 3 8 Wifi Module Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Lenovo Yoga Tab 3 8 Wifi Module Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Open the kickstand by pressing the release button in the center.
    • Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
  2. Lenovo Yoga Tab 3 8 Wifi Module Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the three 2mm screws under the kickstand with a PH00 screwdriver.
    • The third 2mm screw to the right may have an S sticker covering it which you can scrape off.
  3. Lenovo Yoga Tab 3 8 Wifi Module Replacement: 3 단계, 이미지 3개 중 1개 Lenovo Yoga Tab 3 8 Wifi Module Replacement: 3 단계, 이미지 3개 중 2개 Lenovo Yoga Tab 3 8 Wifi Module Replacement: 3 단계, 이미지 3개 중 3개
    • Starting along the edge opposite of the hinge, insert a plastic opening tool between the screen and the backing to begin separating the small clips holding the backing on.
    • Work along the edge and then up the sides, separating the clips with the plastic opening tool.
    • There is adhesive underneath the slot for the SD card so you will need to slowly apply some force to break the adhesive.
    • As the back is separated from the device, be careful to not lose the power button. It may come loose and fall out.
  4. Lenovo Yoga Tab 3 8 Wifi Module Replacement, Wifi Module: 4 단계, 이미지 1개 중 1개
    • Locate the WiFi module connection on the motherboard by following the grey wire along the bottom. Use a spudger to gently pry it off.
  5. Lenovo Yoga Tab 3 8 Wifi Module Replacement: 5 단계, 이미지 2개 중 1개 Lenovo Yoga Tab 3 8 Wifi Module Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Locate the copper foil holding down the WiFi module near where the grey wire connects. Use tweezers to carefully lift up and separate the copper foil.
  6. Lenovo Yoga Tab 3 8 Wifi Module Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the three 2mm screws holding the wifi module to the device using a PH00 screwdriver.
  7. Lenovo Yoga Tab 3 8 Wifi Module Replacement: 7 단계, 이미지 2개 중 1개 Lenovo Yoga Tab 3 8 Wifi Module Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the grey wire from the channel holding it by gently lifting it up with your fingers.
    • Lift the wifi module out of the device with your fingers.
결론
작성자
5다른 기여자 명과 함께
Nicklaus Krems
회원 가입일: 09/25/17
1,073 평판
안내서 8개를 작성함
USF Tampa, Team S16-G2, Eyestone Fall 2017 USF Tampa, Team S16-G2, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S16G2
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 2,097
