주요 콘텐츠로 건너뛰기
Lenovo Yoga Tablet 10 Back Camera Replacement
필요한 것
  1. Lenovo Yoga Tablet 10 Back Camera Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the two Phillips #000 screws.
    • These screws are located behind the stand for the device.
    • Our device did not include these screws.
  2. Lenovo Yoga Tablet 10 Back Camera Replacement: 2 단계, 이미지 1/1
    • Use a plastic iFixit opening tool to pry the edges of the back case loose by placing it in between the edge of the cover and the screen.
    • Do not immediately attempt to remove the back of the case without attempting Step three, or you risk snapping the back cover.
  3. Lenovo Yoga Tablet 10 Back Camera Replacement: 3 단계, 이미지 1/2 Lenovo Yoga Tablet 10 Back Camera Replacement: 3 단계, 이미지 2/2
    • Use the spudger to reach into the center of the device and pry off the back case by giving it a light force upwards.
  4. Lenovo Yoga Tablet 10 Back Camera Replacement, Back Camera: 4 단계, 이미지 1/2 Lenovo Yoga Tablet 10 Back Camera Replacement, Back Camera: 4 단계, 이미지 2/2
    • Remove one 5mm screw using the Phillips #00 Screwdriver.
  5. Lenovo Yoga Tablet 10 Back Camera Replacement: 5 단계, 이미지 1/3 Lenovo Yoga Tablet 10 Back Camera Replacement: 5 단계, 이미지 2/3 Lenovo Yoga Tablet 10 Back Camera Replacement: 5 단계, 이미지 3/3
    • Use the spudger to disconnect the camera and battery from the printed circuit board by putting the spudger in between the connections and the printed circuit board and pushing the spudger up.
  6. Lenovo Yoga Tablet 10 Back Camera Replacement: 6 단계, 이미지 1/1
    • Remove one 5mm screw with the Phillips #00 screwdriver.
  7. Lenovo Yoga Tablet 10 Back Camera Replacement: 7 단계, 이미지 1/3 Lenovo Yoga Tablet 10 Back Camera Replacement: 7 단계, 이미지 2/3 Lenovo Yoga Tablet 10 Back Camera Replacement: 7 단계, 이미지 3/3
    • Use the nylon tip tweezers to push the camera out from between the power button and the kickstand.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Juan Benjamin
회원 가입일: 01/24/19
490 평판
안내서 4개 작성하였습니다
Cal Poly, Team S2-G6, White Winter 2019 Cal Poly, Team S2-G6, White Winter 2019 회원
CPSU-WHITE-W19S2G6
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
“To reassemble your device, follow these instructions in reverse order. “ Including unripping the power switch tail, which is soldered to the board. Look at the last picture!
The camera/speaker assembly cannot be removed without unsoldering this tail.
Fixin Ma Stuff - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 464
