소개
If you need to replace your faulty battery use this guide. The battery is located inside the kickstand, thus you will need to know how to remove the back facing camera and the headphone jack.
필요한 것
Use the metal spudger to push out the lock of the battery compartment by putting the metal spudger between the kickstand and the plastic and applying a force upwards.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
the battery removal is shown to be difficult
here shows the right way
