주요 콘텐츠로 건너뛰기
Lenovo Yoga Tablet 10 Camera PCB Replacement
필요한 것
  1. Lenovo Yoga Tablet 10 Camera PCB Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the two Phillips #000 screws.
    • These screws are located behind the stand for the device.
    • Our device did not include these screws.
  2. Lenovo Yoga Tablet 10 Camera PCB Replacement: 2 단계, 이미지 1/1
    • Use a plastic iFixit opening tool to pry the edges of the back case loose by placing it in between the edge of the cover and the screen.
    • Do not immediately attempt to remove the back of the case without attempting Step three, or you risk snapping the back cover.
  3. Lenovo Yoga Tablet 10 Camera PCB Replacement: 3 단계, 이미지 1/2 Lenovo Yoga Tablet 10 Camera PCB Replacement: 3 단계, 이미지 2/2
    • Use the spudger to reach into the center of the device and pry off the back case by giving it a light force upwards.
  4. Lenovo Yoga Tablet 10 Camera PCB Replacement, Back Camera: 4 단계, 이미지 1/2 Lenovo Yoga Tablet 10 Camera PCB Replacement, Back Camera: 4 단계, 이미지 2/2
    • Remove one 5mm screw using the Phillips #00 Screwdriver.
  5. Lenovo Yoga Tablet 10 Camera PCB Replacement: 5 단계, 이미지 1/3 Lenovo Yoga Tablet 10 Camera PCB Replacement: 5 단계, 이미지 2/3 Lenovo Yoga Tablet 10 Camera PCB Replacement: 5 단계, 이미지 3/3
    • Use the spudger to disconnect the camera and battery from the printed circuit board by putting the spudger in between the connections and the printed circuit board and pushing the spudger up.
  6. Lenovo Yoga Tablet 10 Camera PCB Replacement: 6 단계, 이미지 1/1
    • Remove one 5mm screw with the Phillips #00 screwdriver.
  7. Lenovo Yoga Tablet 10 Camera PCB Replacement: 7 단계, 이미지 1/3 Lenovo Yoga Tablet 10 Camera PCB Replacement: 7 단계, 이미지 2/3 Lenovo Yoga Tablet 10 Camera PCB Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the nylon tip tweezers to push the camera out from between the power button and the kickstand.
  8. Lenovo Yoga Tablet 10 Camera PCB Replacement, Camera PCB: 8 단계, 이미지 1/1
    • Remove the four 1 mm screws with a Phillips #00 Screwdriver.
  9. Lenovo Yoga Tablet 10 Camera PCB Replacement: 9 단계, 이미지 1/2 Lenovo Yoga Tablet 10 Camera PCB Replacement: 9 단계, 이미지 2/2
    • Use a spudger to disconnect the ribbon wire by applying a force upwards.
  10. Lenovo Yoga Tablet 10 Camera PCB Replacement: 10 단계, 이미지 1/2 Lenovo Yoga Tablet 10 Camera PCB Replacement: 10 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to lift up the foil.
    • The foil may tear.
  11. Lenovo Yoga Tablet 10 Camera PCB Replacement: 11 단계, 이미지 1/2 Lenovo Yoga Tablet 10 Camera PCB Replacement: 11 단계, 이미지 2/2
    • Use the tweezers to lift the black tape from the corner of the printed circuit board.
  12. Lenovo Yoga Tablet 10 Camera PCB Replacement: 12 단계, 이미지 1/3 Lenovo Yoga Tablet 10 Camera PCB Replacement: 12 단계, 이미지 2/3 Lenovo Yoga Tablet 10 Camera PCB Replacement: 12 단계, 이미지 3/3
    • Flip the board 180 degrees towards you using the tweezers.
결론
Juan Benjamin
회원 가입일: 01/24/19
490 평판
안내서 4개 작성하였습니다
Cal Poly, Team S2-G6, White Winter 2019 Cal Poly, Team S2-G6, White Winter 2019 회원
CPSU-WHITE-W19S2G6
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 7
전체 시간: 310
