주요 콘텐츠로 건너뛰기
Lenovo Yoga Tablet 2 830-F Camera Replacement
필요한 것
  1. Lenovo Yoga Tablet 2 830-F Camera Replacement, Camera: 1 단계, 이미지 1/2 Lenovo Yoga Tablet 2 830-F Camera Replacement, Camera: 1 단계, 이미지 2/2
    • Remove the three screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Camera Replacement: 2 단계, 이미지 1/3 Lenovo Yoga Tablet 2 830-F Camera Replacement: 2 단계, 이미지 2/3 Lenovo Yoga Tablet 2 830-F Camera Replacement: 2 단계, 이미지 3/3
    • Using the Phillips Screwdriver #00 bit remove the 6 screws.
    • Using the Phillips Screwdriver #00 bit remove the 3 screws.
    • After removing all the screws, disconnect the ribbon cables.
    • Disconnect the ZIF connectors.
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Camera Replacement: 3 단계, 이미지 1/3 Lenovo Yoga Tablet 2 830-F Camera Replacement: 3 단계, 이미지 2/3 Lenovo Yoga Tablet 2 830-F Camera Replacement: 3 단계, 이미지 3/3
    • After removing the motherboard and antennas the camera module is located on the right as marked in red.
    • Remove the three 2mm screws holding the module in place with the Phillips Screwdriver #00 bit.
    • The camera module is also held in place with adhesive so gently remove.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mario Gjyli
회원 가입일: 09/28/17
449 평판
안내서 3개 작성하였습니다
USF Tampa, Team S2-G4, Nance Fall 2017 USF Tampa, Team S2-G4, Nance Fall 2017 회원
USFT-NANCE-F17S2G4
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 683
