주요 콘텐츠로 건너뛰기
Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement
필요한 것
  1. Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 1/2 Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 2/2
    • Remove the two 3mm screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Remove the 2mm screw with a Phillips #00 bit.
    • Using the blue opening tool or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement: 2 단계, 이미지 1/1
    • Remove the three 2mm screws on the back of the left speaker module with the Phillips Screwdriver #00 bit.
    • Remove the ribbon cables connecting the boards to the other electrical components
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement: 3 단계, 이미지 1/1
    • Gently remove the left speaker module.
    • Replace the old left speaker module with the new left speaker module.
    • Be careful not to damage the ribbon cables on the new left speaker module while reassembling the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Charles Rhode
회원 가입일: 09/28/17
588 평판
안내서 3개 작성하였습니다
USF Tampa, Team S2-G4, Nance Fall 2017 USF Tampa, Team S2-G4, Nance Fall 2017 회원
USFT-NANCE-F17S2G4
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 24
전체 시간: 1,918
