주요 콘텐츠로 건너뛰기
Lenovo Yoga Tablet 2 830-F Motherboard Replacement
필요한 것
  1. Lenovo Yoga Tablet 2 830-F Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Lenovo Yoga Tablet 2 830-F Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Remove the two 3mm screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Remove the 2mm screw on the back fo the device with a Phillips #00 bit.
    • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Motherboard Replacement: 2 단계, 이미지 1/2 Lenovo Yoga Tablet 2 830-F Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the six 3mm screws on the back of the motherboard with the Phillips Screwdriver #00 bit.
    • Remove the ribbon cables connecting the boards to the other electrical components
    • Remove ZIF connectors connecting the boards to the electrical components.
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Motherboard Replacement: 3 단계, 이미지 1/2 Lenovo Yoga Tablet 2 830-F Motherboard Replacement: 3 단계, 이미지 2/2
    • Replace the motherboard with the new motherboard.
    • Be careful not to damage the ribbon cables when reassembling the device.
결론
Charles Rhode
회원 가입일: 09/28/17
588 평판
안내서 3개 작성하였습니다
USF Tampa, Team S2-G4, Nance Fall 2017 USF Tampa, Team S2-G4, Nance Fall 2017 회원
USFT-NANCE-F17S2G4
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 20
전체 시간: 1,956
