소개
This guide will explain how to remove the back panel on a Lenovo Z70-80 laptop.
필요한 것
Use your fingers two push both latches away from each other to release the battery.
Pull the battery out.
Remove the two Phillips #0 screws from the bottom panel.
Slide the panel down slightly, and then lift to pull it off.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
