소개
This guide will demonstrate how to replace the keyboard on your Lenovo Z70-80 laptop.
필요한 것
Use your fingers two push both latches away from each other to release the battery.
Pull the battery out.
Carefully pry up the keyboard with the flat end of a spudger and remove all of the 3mm Phillips #0 screws.
Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Pull the keyboard cable out of the socket.
Remove the keyboard.
다른 한 분이 해당 안내서를 완성하였습니다.
