주요 콘텐츠로 건너뛰기
Lenovo bluetooth mouse N6901A disassembly
필요한 것
  1. Lenovo bluetooth mouse N6901A disassembly, Mouse: 1 단계, 이미지 1/1
    • 3 Phillips screws are located under the battery cover, unscrew them
  2. Lenovo bluetooth mouse N6901A disassembly: 2 단계, 이미지 1/2 Lenovo bluetooth mouse N6901A disassembly: 2 단계, 이미지 2/2
    • The mouse cover at the bottom should move freely but at the top is hold by 2 brackets
    • In order to remove the mouse cover, you will need to rock left/right the cover and slide it down (from scroll wheel toward the Lenovo logo)
  3. Lenovo bluetooth mouse N6901A disassembly: 3 단계, 이미지 1/2 Lenovo bluetooth mouse N6901A disassembly: 3 단계, 이미지 2/2
    • At this point, you have separated the mouse cover
  4. Lenovo bluetooth mouse N6901A disassembly: 4 단계, 이미지 1/1
    • Use the appropriate tool to remove gently the power connector. Don't use your finger, you might brake the cable
  5. Lenovo bluetooth mouse N6901A disassembly: 5 단계, 이미지 1/2 Lenovo bluetooth mouse N6901A disassembly: 5 단계, 이미지 2/2
    • The micro switch can be replaced by OMRON D2FC-F-7N but you need to trim the solder terminals with a flush wire cutter
    • When you reassemble the mouse, make sure you don't crush the power cable
결론
다른 2명이 해당 안내서를 완성하였습니다.
Shinn Chyang Chen
회원 가입일: 09/14/11
2,953 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 35
전체 시간: 5,537
